Quote to fit 4 new sockets | Page 3 | on ElectriciansForums
Discuss Quote to fit 4 new sockets in the UK Electrical Forum area at ElectriciansForums.net
Solihull
Hi people how much would you quote to add 4 new sockets?
1st one in living room at shoulder height. Skirting and floor boards will need lifting. Chasing up the wall and sheaving.
2nd in kitchen. Slight chasing in wall and then chasing up back of units to ceiling level all most.
3rd in bedroom into brick wall at skirting height. Slight bit of chasing out of wall and sheaving. Lifting skirting and floor boards up.
4th into a studded wall which is plaster and laff. Socket to go in at head height and chasing down the wall through a fire break then into the floor.
Any advice will be appreciated, thank you
Plaster and laff???
Plaster and laff???
Do people still use 30amp junction boxes?
Yes, why not? if you fit one in an accessible location, nothing wrong with that, if you can locate a RFC leg I could show you how to spur from that loction without even cutting the cable.
Reply to Quote to fit 4 new sockets in the UK Electrical Forum area at ElectriciansForums.net
G
Best Tile Adhesive for Walls and Floors? Voting is now CLOSED - Results are in!! Well done MAPEI! Which Tile Adhesive Did You Use Most During...
Gazzer
G
