Re: R.c.d fault????? Rcd not tests fine but does not disconnec under fault conditions
The test you do for a RCD is what you have done with a calibrated RCD test instument.
If all you tests are good then you have nothing to worry about.
Touching the CPC and neutral is not a test ,Wirepuller has covered this.
