R1 and R2 parallel earth | on ElectriciansForums
Discuss R1 and R2 parallel earth in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
stv292
hi guys and girls,
any ideas on why when cunducting an R1 and R2 and also polarity when it was a closed circuit i had 1.87 ohms but when opened circuit 238ohms. this was on a lighting circuit pme system all correctly main bonded and zs complied.
thanks
Was the main switch still on at the CU? If there were other lights in the circuit with their switches "on" then the measuring current can run from the CPC through the N-E connection up the neutral through the light bulb and back to your line conductor, then you are measuring the resistance of the light bulbs "on" in the circuit.
yes, it was just that circuit i was working on so just that circuit isolated. it was a tidy job before me, they looped the live out the com in a 2gang switch then used the earth as a switch live, then at the ceiling light connected the earth to a single and ran it to the wall light's. all earth's cut off on class 1 fittings. been like it years he said. been put right now.
Reply to R1 and R2 parallel earth in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
Thanks for the input guys. Lighting track is out of the question. The routing (h section guirders and angle iron) means that swa cable clipped...
