R1+R2 Test on outbuilding | Page 2 | on ElectriciansForums
Discuss R1+R2 Test on outbuilding in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Yes that is correct it is a 200mA test (r1+r2) so if it is running through an rcd it will trip it because they are rated at 30mA.
Hi there,
I am just learning and wanted to say that going on the understanding of how RCDs work, it will only trip if the neutral has a difference of more than the rated RCD (ie 30mA in this case) of the supply given to it (in this case 200mA). It shouldn't matter if the system is dead or alive, the fact that you are sending the current is making that circuit 'live' in a way. I guess it would trip if you send a test current of 50mA? Is my understanding correct?
Reply to R1+R2 Test on outbuilding in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
He said something about a fused something as the lights hardly take anything .. I told him was mostly cordless tools so just chargers ..told him...
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
