A
ashspark8318
hi, how do i test for continity at light? which switch position do i need to get a reading? Thanks
readings to be about the same/
lucky guess.. could you run through the test again from how you would carry this test? there is a intermediate switch in the two way lighting circuit. thanks
thanks. i have been told a different way by my am2 prep tutor to wire the 2way intermediate
Thanks very much. so whilst testing for R1+R2 i need to switch the switches individually as murdoch said and test, iprove polarity on the light cicuitThe drawing shown is a standard conduit system intermediate and right, but in domestic it is wired differently, however the method of switching and operating it the same, it's a case of knowing how it works and thats what you need to understand and learn, school boy stuff really.
Obviously with parallel paths disconnected for a true reading . And MDJ you are very patronising just thought I would point that out to you if you didn't realise. I believe he was asking for advice not sarcasm.
