P
pencilpusher
I am doing some R2 testing. I have been removing the cpc from the earth bar and crock clipping it . I am then measuring r2 at the other end of the circuit.
Problem: For example, I removed the cpc for the cooker circuit at the CU. I went to the cooker switch and got continuity. Great. I then realised that the cpc had been placed in the wrong cpc position in the bar. To help me check the other cpc's I decided to do more r2 tests to confirm the cpc ends.
When I tested between removed cpc of cooker (at CU) and removed cpc of immersion heater switch I got continuity. This has happended between cpc's of cooker, immersion and central heating. I suspect parallel paths due to bonding. Am I right? What I don't get is why, if I remove cpc from earth bar and from connection pount, I get bonding coming into it. This is driving me nuts so please help!
