R2 test | on ElectriciansForums
Discuss R2 test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
G
graham123
Is performing an r2 test acceptable for all radial circuits on a eicr? Using a wandering lead?. Seem to see a lot of other contractors doing this. But for initial verification r2 is not accepted
it's OK to measure R2 on an EICR, but i prefer R1+R2 as that also confirms polarity and will pick up any poor connections on the L.
R2 can be handed to use if testing a metal ornate light fitting to check for earth continuity without taking it down But I would still still do An R1 R2 and the light switch to check condition of Live connections as stated.
Get a set of Kewtech litemates, just the job for occasions when it is not practical or possible to take fittings down.
Reply to R2 test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Megger 15 series in my opinion are the best. Had a few 17 series that have put out err 23 codes. This is s an internal clock component issue...
Darren dazz
I will offer some initial thoughts. A workplace so the EAWR 1989 applies, it is statutory and carries legal consequence drawing its authority for...
