radiator switches - problem with identification | on ElectriciansForums
Discuss radiator switches - problem with identification in the UK Electrical Forum area at ElectriciansForums.net
A
Adi
Hi, I am totally new to this forum, based in London, having some electrical qualifications I am mostly dealing with general building maintenance and not very often come across some electrical stuff, but now it's the moment. Basically I have 3 radiator switches to be replaced, the job seemed to be very easy, the trick is I can't find them anywhere and no shop can recognise them neither tell me where to ask, they were all fitted there from new and are the same in every apartment of the building. I had a word with two professional(?) electricians and non of them was able to identify them, so this is headache - have to change them but how.
Thanks [ElectriciansForums.net] radiator switches - problem with identification[ElectriciansForums.net] radiator switches - problem with identification
I don't understand.... You say you can't find where they are switched from yet you have put two pictures up of switches.... I am tired mind I may have not read right.[/QUOTE
The switch you can see on the picture is faulty so this is the reason I want to change them, the problem is that nobody can identify them and nobody has ever seen this type. I was just hoping somebody knows them and where to buy them from
Do I see a relay built into that unit? Are the heaters controlled also by separate thermostats? What is wrong with the existing ones? If difficult to obtain, they might be repairable unless the whole thing is smashed.
And check the switch and fuse modules for a brand name moulded in that won't show in the photos. My hunch is that they are custom relay units made by the heater supplier, using bought-in switch and fuse modules. I was trying to identify those at least from the shape of the fuse carrier but can't place it.
Reply to radiator switches - problem with identification in the UK Electrical Forum area at ElectriciansForums.net
When I first started, I stripped out a house for a rewire and got my hands on a switch with an inlay and transparent cover. Filled it in with...
Part III:). I think I have clarity-having spoken to my electrician who installed my heaters, he said that the part of my fuseboard that is...
2 3 4
Recommended Sponsor News
Hi everyone,
