Radio telemeter series K | Page 2 | on ElectriciansForums
Discuss Radio telemeter series K in the UK Electrical Forum area at ElectriciansForums.net
Isle of Arran
I have a Horstmann Radio Telemeter series K that is not working. I have one consumer unit with all circuits. This consumer is fed via a normal standard tariff meter. I have a econ 7 timer for the hot water tank with two immersion heaters. Do I need to install a consumer unit for the hot water circuit and connect it to the radio telemeter.
Any help woul be gratefully accepted.
Many thanks
[ElectriciansForums.net] Radio telemeter series K
Probably, but you need to do some research into how much electricity you use over a few days. Note the meter readings at midnight and at 7am over a few days, first with the water heater on all the time, and then with the water heater only on between midnight and 7am.
If I was a mind to reconnect the RTS and install a small 2way CU just for the economic water heating, As I not familiar with the RTS shown in my picture and the correct way to connect it, could you explain how I need to connect it?
Thanks for any help.
John
I don't think you will find anyone on here who will guide you in connecting it, as already said you would be interfering with an electric meter, although It's already been messed with and left without seals.
Reply to Radio telemeter series K in the UK Electrical Forum area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
Pretty common for lights and sockets to get a Re-wire and the Eco7 circuits usually storage heaters /water heater to remain left as was. As for...
