Well Im tempted to cut them but ever do
Discuss RCBO neutral & earth tails in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Don't want to pee on anyones bonfire, but you are not supposed to cut them back. Cant remember the reason why, but do remember seeing written somewhere.
Cheers………….Howard.
I vaguely remember it being something to do with the minimum cable length (RCD to N Bar) to enable the RCD to work to spec. Cant remember the technical reasoning behind it .....
Alas, just another old wives tale i'm afraid. There is no reason whatsoever not to dress and cut to size to suit the installation.
I'd say that virtually every RCBO's neutral tail and functional earth lead has been, or will be dressed, and cut to size on our project. There is nothing worse than seeing a DB/CU filled with unwanted lengths of RCBO tails and leads. Get them dressed and cut to size, not forgetting to fit a suitably sized pin ferrule...
Straight from the horses mouth, for Schneider at least.
Taken from Schneider's FAQ
Reply to RCBO neutral & earth tails in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
