sparkygrant
Hi all help please,I tested a6 amp rcbo30ma at board with out load connected the rcd results are 310ms at times 1 and 50ms at times5 so I changed it thinking it was faulty tested new 1I fitted got same results I then rcd tested another rcbo in the board another lighting circuit results are fine I then tuck the 1I tuck out because I thought it was faulty and put in my board at home and the results was fine has any one come across this before and can someone please help with this situation cheers
