RCBO wiring direction? | on ElectriciansForums
Discuss RCBO wiring direction? in the USA Electrical Forum area at ElectriciansForums.net
farnja
USA
Hi All -
I have a new-to-me boat and I'm trying to better understand the electrical system. I'm sorry if this is the wrong forum, but it's a French built boat using all Hager MCBs and switches. None of this stuff exists in the U.S., afaik.
I'm not on the boat at the moment to test but from these photos I snapped, it looks like I have an Overcurrent + Differential breaker taking input from the bottom, then it has bus bars on the top to two MCBs, then those output from the bottom. This seems strange to me but wanted to know if 1). Is this the case? and 2). Is this common and is there anything wrong with that?
Attached are photos of the front, then bottom, then top.
Thanks in advance!
[ElectriciansForums.net] RCBO wiring direction?
Wish we had these in the Uk as well. Dual busbar
It appears to be correct.
The symbol next to the 1 and 3 on the ADC732F on the left show arrows pointing toward each other, which I assume means bi-directional.
Reply to RCBO wiring direction? in the USA Electrical Forum area at ElectriciansForums.net
My thoughts exactly! Snowed under with work at the moment, so might have to pass it on 😬😬
Single Pole, Single Pole Switched Neutral, and Double Pole are all different things. Hager RCBO's are Single Pole. I was recommending Single Pole...
5K
Could be. Both the thermostat and cutout/thing that we see in the pics seem to have capillary tubes behind going somewhere!
You are correct about that wire being # 10 and it actually needs to be # 3 copper for a 100 amp breaker. At the footage you explained you...
Hi, I'd be very grateful if anyone could help me here. Below, I've pasted a sketch showing how my oven is currently wired up, followed by 3...
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
