RCBOs with 1 flying wire. | on ElectriciansForums
Discuss RCBOs with 1 flying wire. in the Australia area at ElectriciansForums.net
Bul
Do RCBOs normally have 2 flying leads - neutral and earth?
Are there "old" rcbos and new types.
The reason I ask is that I have bought Proteus RCBOs and they have a flying neutral wire only.
I've never fitted RCBOs before and am just a bit confused.
Any explanations appreciated.
Bul
sorry to go off track slightly but when connecting an rcbo do you guys normally use a seperate earth terminal for the functional earth or use the same connection as the cpc for that circuit?
Reply to RCBOs with 1 flying wire. in the Australia area at ElectriciansForums.net
I think I've found the answers to my questions... I can just do a straight forward wiring i.e. connect the 3 wires from the armoured cable to...
2 3
