rccb and mcb | on ElectriciansForums
Discuss rccb and mcb in the UK Electrical Forum area at ElectriciansForums.net
stavrosano
hi all..
i would like to ask a question regarding rccb..
In cyprus we use TT system and i would like to ask about the connection of rccb and mcb as a consumer unit.
Is it ok if i use rccb and mcb instead of mcb and rccb in the connection order.
to be more specific..the main supply goes to rccb and then from the mcb i supply my main db in the house.
The two of them are connected with a busbar on the below side.
Or to i have to put the main supply to mcb and then from rccb to supply the house?
Hope i was clear enough
Thanks in advance
But the EAC(electrical Aythority of Cyprus) didnt not approved it:S and the explanation was that mcb must lead rccb in order to fully isolated the installation..the psc was 1200A and the rccb had Ics of the rccb was 1000A
Reply to rccb and mcb in the UK Electrical Forum area at ElectriciansForums.net
<= This The RCD looks at any current imbalance between the cables routed though it, if N is not used then no current so it matters not from a...
M
I meant EIC, No idea why I put EICR down, thanks for the clarification
