Rccd Tripping | on ElectriciansForums
Discuss Rccd Tripping in the Australia area at ElectriciansForums.net
P
pjelec
I have rewired a small internet shop. I have tested all circuits with an Insulation Resistance Tester. I have >999 reading on all circuits.
About twice a day the RCCD trips out.
He has 3 Surge Protector leads which the computers are connected to. When I test the Protectors L-E & N-E my readings are 000 which means is a really low reading.
This could be the cause of the RCCD tripping out but surely the protectors dont cause this.
Spoken to the Manufacturer but got no help at all.
Do not want to risk removing the protectors as the computers could get damaged.
Hope someone can help
Defo worth researching about circuit/overcurrent protection when functional earths involved. All those PCs putting small amounts of current down the earth going to screw up the rccd's you have. !
I remember reading an article on this somewhere, then saving a copy - not sure if this is any help, but it suggests ...
"Where it is necessary to specify a residual current device with a residual operating current of 30 mA in order to meet the requirement for additional protection, such as in a socket-outlet circuit, then in order to keep the expected protective conductor currents well below the residual operating current it may be necessary to replace the proposed single circuit by separate circuits each with its own RCD."
  • 2007_25_winter_wiring_matters_protective_conductor_currents[1].pdf
ya-the leakage will accumulate with pcs
you'll need a number of rcbo's if you're providing 30ma protection
'high-integrity earthing' may be another consideration on these circuits
i know surge protection downstream of rcds can be an issue,dunno any specifics though
Well, as my other comments regarding the opportunity to omit RCD protection are falling on deaf ears, maybe a look at a thread from the *other* forum may be of help with this problem...
IET Forums - Surge suppression sockets
Or even here if you want the DIYers opinion....
Rccd tripping - DIYnot.com - DIY and Home Improvement
But if you don't wanna read it then so be it! :)
Reply to Rccd Tripping in the Australia area at ElectriciansForums.net
Yup will do exactly that when I'm back down there. Thanks for the help
Which rcd is it? Is it one for everything, one for a few circuits?
