Rcd advice needed faulty or fault | on ElectriciansForums
Discuss Rcd advice needed faulty or fault in the UK Electrical Forum area at ElectriciansForums.net
Portsmouth
So had to fit a new shower as old one kept tripping the rcd after few seconds assumed the shower was to fault as made a buzzing noise and tripped, on fitting the new shower it had same faukt so checked pressure of water no issue then checked wiring at box also no issue so moved onto next possibiliy of short on cable.
Yes maybe should of used multimeter and tested each one out but easier as short run in walls so run new cable exactly the same.
So decided to wire a small flex with bulb holder on that trips rcd changed the 40amp mcb to a 16 amp tried light also trips could this be a faulty rcd its rated 80amp 30ma, we also tested the the curcuit with every mcb turned off with only shower circuit on and also tripped.
Any help would be greatly appreciated as would like to think in a 6 bedroom house with each room occupied that of rcd was faulty then it would trip as currently has approx 8 circuits on and only randomly started to happen nothing new has been added.
[ElectriciansForums.net] Rcd advice needed faulty or fault
Not an Electrician then? about time you got one in to test the system properly with the correct test equipment, "lamp and a bulb holder oh dear me DIY disaster on the horizon if I'm not mistaken, do yourself and whoever is helping you a big favour, leave it well alone and get a Sparky in to sort it for you, before you do yourself and your Mate some mischief.
Been doing electrics since the age of 10 mate dads fully qualified also worked doing electrics for both single phase and 3 phase air conditioning installs he is 18th edition certified and have been trained to the qualified standard of him.
I also run all the electrics in the house when was converted in the property it located in and as you can see was fully inspected and checked by a fully qualified electrician and signed off as you can see in the picture of the fusebox I am more than capable of checking things out.
Also I have checked all earths neutrals and lives on the mcb
The 18th edition of BS7871 aint out yet?
Checked? what with?
And it maybe 17th he had as when working with him many years ago it was 16th haven' done a huge amount of electrics in last 15 years however have done bits a pieces in that time if it' not going to be a simple fix then I'll call my mate out to have a look but just can' get my head around why it trips when it's a 1 cuircut feed to shower of around 8 feet and with every mcb switched off it still trips rcd and on a 16amp breaker still trips the rcd with a 1 bulb light fitted
When house was rewired he checked every plug socket unscrewing checked all wiring and earthing and measured each individual with his testing equipment and also pat tested all appliances on house he is full nic eic certified
Also forgot to mention I also tried the shower on the unprotected rcd side still tripping the rcd out
Where is the circuit for the shower? What rating is the MCB?
Strikes me that without proper test kit and the knowledge to use it and interpret the results you may well be wasting your time ....
40amp mcb and mcb is also not tripping used the spare 16amp with lightbulb circuit and still done same a ramp test could be beneficial to test the rcd but then changing the rcd of possibly faulty is also easy main thing being tho of the rcd is faulty it would trip with all the other circuits on board under load and would assume with then isolated that if there was a fault on a circuit with all mcbs turned off that would isolate any fault.
Shower is currently not on any circuit as removed from box and left isolated outside of fuse box
Punctuation would help!
using what?
regarding isolation of circuits using MCB's, best you ask your dad about how RCD's work ....
The idea of this post is to find out if the rcd could be the possible fault or if it could be a fault somewhere else but surely with one wire direct feed when switched off the rcd doesn't trip meaning there shouldn't be a fault on the other circuits as it' been fine for over a week.
40 amp mcb missing from rcd side so now on 16amp mcb on non rcd side and still tripping rcd. not possible if you are doing things correctly.
If there is a shower isolator check that for correct operation, tightness, burnt out etc etc.
If you been doing it from the age of ten i would not be posting on a forum for advice on basic fault finding. but good luck and happy showering :)
With the greatest respect Stu. I'm with the others I think it's best to get someone qualified to look at this.
It's going to involve disconnecting and testing circuits, and I personally wouldn't want to advise someone over a forum especially when it could cause serious injury or death.
At last
The switch has also been replaced and basic fault finding steps have been looked at all earths neutrals and lives checked on box and nothing has been added or changed so just cannot understand how such a fault just appears the house was only rewired 2 years ago.
Reply to Rcd advice needed faulty or fault in the UK Electrical Forum area at ElectriciansForums.net
I would add though that a typical good TT rod of 100 ohms only needs 3V to have 30mA flowing and so trip an RCD, you might find that sort of N-E...
Thank you for taking the time to help explain this - much appreciated
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3
4K
One of the things to consider with lamp holders that have lamps missing is that there is also a neutral pin, shoving your fingers across those...
