Discuss rcd as main switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
TBH you can get a half decent set of RCBO and 100A switch and Enclosure for same price as a RCD box and MCBS!!
for only 4/5 circuits, main switch + RCBOs every time. compliance and convenience.
Rcd main switch and inconveniance
Under previous ediions it was the bees knees, up to date,all thought out, bestest system available
Millions of installations have this sytem (My own included)
Suddenly,with the advent of the 16th and 17th ed they are seen as terrible afflictions that cant be tolerated
Minimising in conveniance is usually touted as the pinnacle of the critisism
Does a dual rcd board or a dist board with a full quantity of rcbos overcome the coin meter ?
If minimising inconveniance was an essential safety feature, then coin meters would be outlawed
Too much of pointing fingers of accusation surround this subject
By all means segregate circuits so that it minimises problems,but with the understandimg that inconveniance cant be eliminated
Systems with an Rcd main switch are only slightly less perfection than the sytems installed to replace these "out of date obsolete non regulatory types"
Nothing much wrong in my view with a front end RCd board
Reply to rcd as main switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
