RCD being used as a main switch | Page 3 | on ElectriciansForums
Discuss RCD being used as a main switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Reply to RCD being used as a main switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all. Try to keep this nice and short. Had an EICR fail on a health centre due to corrosion on main supply which was causing high Ze values...
Thank you so much for that! When I went to do the Ze at the DB, I tripped the RCD in the CU in the house, I understand that's a hard question...
