Rcd Board with round knockouts | on ElectriciansForums
Discuss Rcd Board with round knockouts in the UK Electrical Forum area at ElectriciansForums.net
suffolkspark
Hi all, im having a mare trying to find a board that suits my requirements. Can anybody reccomend a sensibly priced off the shelf solution.
I sinlmply want a 100A 30mA upfront type A rcd.
10 usable ways (no size constraint so can be bigger)
ROUND KNOCKOUTS
So many now seem to have square knockouts and I've got lots of 20mm swa and 20mm conduit to bring in.
Hager either have square ko or no ko in that size. lewden all square knockouts, mk and Eaton seem to be type AC rcds.
Help
The Wylex board I had recently was all round holes on the sides/top/bottom (square on the back).
Do you really want a 30mA up-front? That seems a bit low for 10 circuits (though maybe they are all low-leakage ones).
The Wylex type A RCD one CEF stock is 80A so would have to look if they do it in 100A.
Yes, seems they do:
Are the axiom type A rcds? I'll have to check, wylex sounds like best contender, 80A incomer will suffice as it's a submain.
I dont wanna messabout with galv trunking etc just wannataje my nice 20mm items into nice 20mm holes
[automerge]1588782629[/automerge]
I have been speaking to hager technical and he didnt mention that, their catalogue is a nightmare
I think @telectrix solution is really by far the best, as very likely you won't have enough knock-outs of the size you want on one side.
need to check the depth of the box before the lid and if insufficient depth, space the trunking off by 1/8" or so.
It's all on show so want it to look good. Just looking for that on the shelf item that should exist
plenty room here for 20mm holes. easy drill as well:
[ElectriciansForums.net] Rcd Board with round knockouts
Reply to Rcd Board with round knockouts in the UK Electrical Forum area at ElectriciansForums.net
