Rcd fail half test | on ElectriciansForums
Discuss Rcd fail half test in the UK Electrical Forum area at ElectriciansForums.net
M
monkee
Cheers guys for all your replies, sorry I did not answer all your questions but I did return with two replacement RCD units swapped them over
still the same issue I contacted meggar for some input turns out my tester is faulty I went to three other installs and carried out the same checks
and the same thing happened doing the ramp test with no results as well as the half tests but all the other functions seemed ok
This unit is a LRC220 only three months old.
bring back robin my last kit was over ten years old never a problem.....
meggar are very helpfull so thats a good sign
any one esle having problems with test kit.....:dizzy2:
Reply to Rcd fail half test in the UK Electrical Forum area at ElectriciansForums.net
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
They ought to be able to check for the voltage going completely off using one MCB off at a time to confirm that. That would be my assumption...
