L
lim88
A customer has a RCD spur unit spurred off a ring supplying their garage. It is all wired in 2.5mm twin, and in the garage there is only two sockets with nothing plugged in.
The RCD spur unit would not reset so have replaced with an identical one. When the power was turned back on the the spur unit was already on and everything was working fine, but when i tested it via the test button there was a lovely flash and the RCD in the ccu tripped too. And that broke the spur unit.
I have dead tested all the cables and all the readings are perfect.
Is it a problem with the RCD spur units or is there anything else I can check that I have missed?
