RCD fused spur units . Which ??/ | on ElectriciansForums
Discuss RCD fused spur units . Which ??/ in the UK Electrical Forum area at ElectriciansForums.net
LukeD
Nearly Esteemed
Supporter
Have not needed one for some time ! Now need to add one in on a small job. Any stand out as been good value etc ?
If I have to fit one I always fit these.
Never had an issue with them!
Powerbreaker. A bit more expensive, but I find I have problems with the cheap ones
The cost of this unit is fine. They need a huge level of works and full rewire etc etc .But life is tricky for them .They are only a few years left on earth with luck and the house wont lend itself to been taken apart . Its one of those "better than nothing " jobs to try and make things better.
Reply to RCD fused spur units . Which ??/ in the UK Electrical Forum area at ElectriciansForums.net
J
The rcd spur being fitted is probably because there wasn't rcd protection of that supply.
2 3
