RCD holding but won't hold any load on any circuit | Page 3 | on ElectriciansForums
Discuss RCD holding but won't hold any load on any circuit in the UK Electrical Forum area at ElectriciansForums.net
P
Phil G
Hi guys I've just rewires the power in a cottage due to the plasterer putting a few screws through cables. I have fitted a new wylex rcd 8 way board and I have got a shower,ring,ring,radial and lights on it. The rcd will hold but if you plug in more than a boiler or a radio it trips straight away. I've tested the circuits and there is no damage to any of them. The lights hold on now too. I've not caught a cable in a box or screwed through one. It's not a split load board so crossed neutrals isn't going to be an issue.
I'm really stumped. Any help would be great
Reply to RCD holding but won't hold any load on any circuit in the UK Electrical Forum area at ElectriciansForums.net
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
Exactly. I was going to ask on the earthing once he clears this boiler fault (suspect on internal component). OP mentions oil boiler but makes no...
