RCD Keeps tripping and not mcb and not on the same side as MCB | Page 2 | on ElectriciansForums
Discuss RCD Keeps tripping and not mcb and not on the same side as MCB in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi - yep I'm going for the N-E fault too - and I raise that it's in one of the 1G to 2G outlet conversions you've just done (trapped N or some such) :) .
Hello hoping someone can urgently help with an issue I am having.
I am carrying out electrical works on a 2 bedroom flat that is being refurbished. All I have done is changed single sockets to double sockets. Taken away a socket that was spured off another socket. Moved some lights into the middle of the ceiling and moved 2 light switches.
I am also not sure if the fault was already there or not but everytime I plugged in something that draws a fair amount of power I.e heater or grinder it would trip the rcd. I thought it may be an rcd fault so I moved the mcb to the other rcd and changed the rcd I thought was faulty. Now what is happening is when you plug something in that draws power it stays on but still trips the same rcd that I changed even though the mcb is not on that rcd side ?
What could this be ?
Did you move the neutral to the other neutral terminal block?
as this would be the reason that the other RCD could be tripping out
I think that the reason the RCD tripped out in the first place would probably due to a neutral to earth fault, if this is so you want to move circuit back (together with neutral) I can't see your profile so I hope that this is a DIY job and not a paid job if so there has been no mention of testing.
Hello mate. Any idea as to the construction of this 2 bed flat? Would you know if the ceiling is suspended and fixed to tin hat?
Do you ever assist anyone or say anything positive? I thought the whole point of this site was to help out fellow sparks
defiantly maybe.,
on this forum there will be a little criticism from time to time to people not knowing what their are doing .
has they say don't like the heat stay out of the kitchen (tin hat on )
plus flack jacket .
defiantly maybe.,
plus flack jacket .
Criticism and banter are one thing. Trying to be a smartass incessantly is another thing all together!
Reply to RCD Keeps tripping and not mcb and not on the same side as MCB in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Exactly. I was going to ask on the earthing once he clears this boiler fault (suspect on internal component). OP mentions oil boiler but makes no...
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
