Hi all, was hoping one of you could help. I’m in the process of buying a house and a few things stood out which I don’t believe meet the regs.
Firstly their is an RCD which I believe is wired into the shower. Does this meet the current regs? I was on understanding the RCD would really need to fitted at the CCU not half way down the circuit. (I’ve noticed the RCD casing is cracked anyway so assuming it needs changing. But interested to know if the location is also an issue).
Second question, the bathroom has a cable covered by some trucking for shower isolater. I don’t really feel this would pass testing and inspection, would I be correct on this? Finally the extractor fan has an exposed cable though I can’t see any exposed conductors. I think this would be fine but see what your thoughts are?
I’m currently qualified to level 2 but due to COVID hasn’t been able to change careers to start working as an apprentice. So apologies if I’m asking obvious questions.
