RCD not tripping on test. | Page 2 | on ElectriciansForums
Discuss RCD not tripping on test. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Tell me you actually had the supply switched on when you tested...
Reply to RCD not tripping on test. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If it’s rcbo’s, then it’s 30mA per circuit… an rcd mainswitch is 30mA for ALL circuits It may just be a cumulative earth leakage which was just...
Exactly. I was going to ask on the earthing once he clears this boiler fault (suspect on internal component). OP mentions oil boiler but makes no...
