Rcd not tripping when tested ? | Page 2 | on ElectriciansForums
Discuss Rcd not tripping when tested ? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
See im baffled by the ze yes water and gas bond disconected Defo tt even got a note on the cut out dont supply PME ,16mm to 3/8 spike at source then a 16mm 3 core swa via a switch fuse to the DB, i never disconected outgoing neutrals on my rcd test at the unit its self , the testers only 3 months old but im hearing there are issues with the earth pins inside it's a robin MFT going to borrow a mates and see if thats the issue, but i just can't understand one working and the other not. Looking in the board im not 100% its not been adapted from a old 100amp 30/ma split load style and the busbars etc might not be right but it all seemed to be conected fine to me. A longer look maybe required apon my return i think.
Post some photos of the DB, many heads looking at this may well be better than one. I'm not aware of the Robin MFT (what model? KTS1625?) earth pin issue you mention.
the starbreaker RCDs are weird. one takes up 3 ways and one takes up 2 ways. not interchangeable. that's the only thing i hate about these boards.
Thats the one the first rcd has 2 pins which span the busbar giving you your l and the Neutrals one in one out ( conected either way acordinf to the instructions, the other has live in from the btm of the MS and the neutral from the common n bar, then n up to the respective n bar, this is all fine guess it must be a wiring issue of some kind , start from the begining work my through
An Ra of 0.70 ohms on a 3/8'' twig?? Not even in your wildest dreams!! lol!!!, Even the dammed cable is bigger than the spike it's attached too....
Telling you now ZE of 0.70 droping to around 0.63 on zs I'm curious as to why its so low but thats what im getting, im back next week with a another tester to double check readings
just a quick update on this ,Been back today changed the bus bar and fitted 4 seprate rccbos got 3 out 4 curcuits passing the rcd and other relevent tests now just 1 ring to go now that trip for love nor money but ever other test is fine !
And the outstanding Ra values on a 3/8th twig??
Reply to Rcd not tripping when tested ? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Build up of Earth leakage from multiple machines and the planner just tipped it over the edge?
Yes I touched on diverted neutrals when I went over guidance note 3 the first time but I’m doing a second round and going between all books whilst...
