rcd not tripping | Page 2 | on ElectriciansForums
Discuss rcd not tripping in the UK Electrical Forum area at ElectriciansForums.net
M
matt12321
hey all
ive been called to a caravan where the power keeps tripping out. ive got a 30ma rcd, which feeds a db with main switch, zs of 16.6 and all circuits clear. when i drop the 10mm tails off the load side of the rcd and test on x1 im getting >40 and x5 >400. and >51mA. ive tried 2 new rcd's and all the same. however with the tails reonnected and test done at a socket im getting >40 x1 and 19 x5 and 46mA.
what is going on?
thanks
and to test the device at a point near to it...disconnect all other circuits fed from it apart of course from the one you are using to carry out the test...but disconnect all loads first..
You using second hand RCD's?
Never used mcg but on a quick google they look identical to CPN and they are the worst RCD's ive ever seen. I'd even take protek over them and thats saying something.
Buy Hager, you only buy once not twice, thrice...
Reply to rcd not tripping in the UK Electrical Forum area at ElectriciansForums.net
Yea all out circuits were disconnected & Rcd ramped tested Think this will be the right way forward,with EL clamp meter Cheers have a nice Christmas 😎
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
