hi
on an installation i am about to work on it is a 2 phase system, L1 phase has been split between 2 cutout fuses
so L1, L1, L2, N & TT earth
if a 4 pole time delay rcd is used as the incomer will the rcd work correctly under fault condition, and also will the test button work as normal? Manufacturer will be hager.
thanks for help
thanks for help
