T
The General
Stop it, you must. Struggling to think of witty reply, I ambecoming a good spark you will be.
Good answer, one I could not gather myself to post.I think that the fact that the Regulation states: 'circuits of the location', that it is pretty clear that the Regulation refers to the circuits of the location.
It may even be argued that circuits which pass through the location are also covered by this Regulation, as they used to be in the 16th edition.
I would have thought that it is fairly clear that the zones do not define the location, as there is a Regulation relating to the placement of socket-outlets outside of the zones.
I thought that one of the changes in the upcoming amendment was to ensure RCD protection on any circuit that passes in or through a bathroom to make sure that lights were now RCD protected, which implies that previously they didn't have to be. (Note: I always RCD protect them, I'm just raising a point, don't lynch me)
Here we go again, IET speak Vs common sense.
Only the IET could issue a clarification that causes confusion.
Said it before, will say it again.
The IET should get the plain english society to review the regs before the update is printed!
I would be happy to undertake that task for a small fee and could even translate it into Geordie with a bit of help from Wor Lad Trev.![]()
Then no bxgger south of the Watford Gap would understand it!
Then my work here would be complete!!
Just think man - if none of the southern jessies could understand it they wouldn't be able to work and WE would be gannin doon there and grabbing it all.![]()
