Can you put an RCD on the supply tails of property instead of replacing the db does this comply with current regs as you cant have a rcd as a main switch.
Discuss RCD on Supply tails in the UK Electrical Forum area at ElectriciansForums.net
Reply to RCD on Supply tails in the UK Electrical Forum area at ElectriciansForums.net
