Rcd outdoor skt. | on ElectriciansForums
Discuss Rcd outdoor skt. in the UK Electrical Forum area at ElectriciansForums.net
G
gregorabbott
Hi guys quick question. Neighbour wants outdoor skt at garden shed. Her house has no rcd protection. Old rewirable fuse board. Cable to be buried underground. Going to spur off closest skt, then out to shed in armour cable. Without upgrading the fuse board is there any way I can rcd protect the armour cable? Taking the armour cable back to the fuse board and fitting a seperate rcd enclosure is practically impossible. Thanks for any suggestions.
In my line of work I don't do much of this sort of thing so out of laziness I asked on here. But it just seems to be full of smart arses. After checking the regs book I can see no requirements for rcd protection for cables buried underground. Reg 522.8.10 only states that a cable buried underground shall incorporate an earthed armour or metal sheath and should be buried at sufficient depth with suitable marking tape etc. sorry for any inconvenience. I was wrong to assume the cable would need to be rcd protected.
So step one, you looked it up - the next poser is what depth does it need to be buried at?
Reply to Rcd outdoor skt. in the UK Electrical Forum area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
