Hi,
My conservatory has 4 x double sockets and operates from a 13amp switched fused spur.
I've just run an outdoor double socket from one of the inside sockets so I can use a fishpond pump.
Q: Should I of used a RCD protected outdoor socket or am I ok replying on the internal 13amp fused spur?
Or would I be better of replacing the 13amp fused spur for a RCD proected version which then would protect all the sockets in the conservatory?
TIA.
TIA.
