RCD protect conservatory | Page 2 | on ElectriciansForums
Discuss RCD protect conservatory in the UK Electrical Forum area at ElectriciansForums.net
Birmingham
Hi,
My conservatory has 4 x double sockets and operates from a 13amp switched fused spur.
I've just run an outdoor double socket from one of the inside sockets so I can use a fishpond pump.
Q: Should I of used a RCD protected outdoor socket or am I ok replying on the internal 13amp fused spur?
Or would I be better of replacing the 13amp fused spur for a RCD proected version which then would protect all the sockets in the conservatory?
TIA.
it's true, mate. her mate's birthdaysaturday, so they gon on a jolly.sadly she has to cut short as daughter is unwell.she be back later. i need to tidy up and kick out the floozy.
Another thread hijacked by small talk.
Sorry, OP.
As others have said, having 2 rcd’s in series can be a nuisance. A fault outside may trip either or both rcd’s
You will also be aware that you have 5 points on a radial circuit limited by the 13A fuse. Can’t go plugging in loads of heaters in the conservatory in the winter.
Thanks Barnaby.
Yes Pete the CU does supply RCD protection to the whole of the house, which then leads on to the fused spur switch in the conservatory.
I suppose my original question should of added, what would the benefit of me putting a rcd double socket outdoors insead of the cheaper standard outdoor socket?
There is no benefit as you already have RCD protection at the consumer unit
Reply to RCD protect conservatory in the UK Electrical Forum area at ElectriciansForums.net
Why aren't you asking them?
I seem to find two types of installation in older houses in which electric showers have been added: those with shower fed from an MCB without RCD...
nicebutdim
N
