F
fixit4u
HI ALL,
ANYONE SHED SOME LIGHT ( PARDON THE PUN ) ON RCD PROTECTION FOR BATHROOM CIRCUITS DOMESTIC/HOTELS ETC FOR PERIODIC TESTING,AS I WAS UNDER THE IMPRESSION THAT ALL BATHROOM CIRCUITS REQUIRE RCD PROTECTION !
THERE SEEMS TO BE A BIG DEBATE AT MY WORK AS IF THIS APPLIES TO BATHROOMS IF THE PIPES,LIGHTS,SHAVER POINTS ETC ARE BONDED WITH > 2.5MM CABLE THAT THIS DOES NOT APPLY ? OR THE ONLY CIRCUIT IN THERE IS LOW VOLTAGE LIGHTING ?BUT HAVE FOUND NO REF TO THIS ANYWHERE,THE COMPANY HAS TRIED TO PUT AN END TO THIS DEBATE FINALLY AS WE ARE ALL GETTING A BIT ****** OFF WITH IT AND PHONED THE NIC TWICE TO BE TOLD NO RCD IS NOT REQUIRED AND THEN YES THAT IT DOES ON ALL BATHROOM CIRCUITS ?
ANY HELP PLEASE !!!!!!!!
