RCD protection for circuits in a toilet (not shower/bathroom) | Page 2 | on ElectriciansForums
Discuss RCD protection for circuits in a toilet (not shower/bathroom) in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
i think alot of new people on the forum will agree with me that if you come on new and not part of your "click" then they people on here that like to undermine people because they have alot more experience then others. They people on here that will just post none useful and off topic comments to try make themself look good infront on their peers.
Im just saying
You are wrong,this is a forum for professional Electricians. I have not commented up until now, it seems quite obvious that you do not have the knowledge/ competence to carry out such tasks. If I am wrong will then I apologise, you don't contribute much either, maybe if you did folk might just be more helpful.
The requirements to provide RCD protection for circuits are only to be found within Chapter 7 (special locations) of BS7671.
A circuit which does not supply equipment, or pass through a special location, will not require RCD protection.
Was not aware when I joined this forum, that it was restricted to professional electricians.
There have over the years been a number of queries from non-electricians.
then maybe you should apologise Dave.
Yes i understand it a forum were they should be give and take. As i did say earlier i hold me hands up to the fact im taking more than giving. But same time nobody once to give you a chance to get to know people and bond with people on here, they just to quick to jump the gun and put you down.
The reason why i asked this question is I didnt think RCD protection was required but was asking advice of the more experienced guys incase i was missing something and all it has turned into is a bunch of people jumping down my throat. If you didnt want to contribute wouldnt of it just been eaiser all round for you not to reply anything.
It was given a code 3 with lack of adequate RCD protection.
I think the comments about electrician and non-electricians are totally off topic so not sure why it even was mentioned in the first place because as you point out non electricians use this forum also.
My questions was to make sure I wasnt missing anything. I found it strange that someone had suggested RCD protection was required for these circuits and was thinking maybe the guy that conducted the EiCR had got confused with "special locations" were his recommendations would of been correct. I was just asking the advice with the more experienced people to make sure i was right in my thinking but instead as my previous comments they some people that just want to jump down your throat and put you down because you not part of the "click"
Paul, if you are feeling alienated and victimised on this site I would suggest that it is mostly from your own actions. Why should your conduct on the internet be any different to the physical world ?
Imagine working on a site where you wander into the site hut and introduce yourself, have a chat with the other guys at break times, and get involved in other's chats day after day.
Now imagine the same site where a fella walks into the hut, asks about a coding query, gets peoples' opinions then walks out of the hut without a word and never comes back to say thanks for the advice. After the seventh time of doing this would you not expect others to start questioning his competence and getting annoyed with his lack of manners ? Would it then be reasonable to accuse the hut dwellers of being excluding and elitist ?
Perhaps if you started again with a bit of info for everyone on the site. Your qualification level, experience etc, as your profile is blank, particularly your qualification and experience relating to periodic reporting.
Hi guys,
ive came across a couple EICRs conducted by other electricians that are unsatisfactory due to lack of RCD protection.
So, on the EICR, what's the reason given for requiring RCD protection (any reg numbers?) and what code has been allocated?
If it's a code C3, then how does that make the result of the EICR 'Unsatisfactory'? Surely a C3 indicates that improvement is recommended?
paul, sometrimes it's the way you word yourposts.if you had said in your OP " i've seen a EICR where they have made a judgement that i disagree with, does anyone agree with me?" youmight have gotten more positive replies.
yes your correct, i should of worded it in that way.
Sorry yes it a code 3, but they also code 2s on the report which makes it the unsatisfactory.
Look, i have no problem with people criticising me, but the posts that i have no ended up replying to is mainly down to people replying with rude comments. Replying back to rude comments would on either result in an argument which im not here for, or waste a couple hours of time like is has done here today talking off topic.
so yes maybe i should explain myself more. I hold my hands up to that an apologise for it, but at the same time they certain people that should think before making rude comments as it really uphelpfull
In the time it took you to type all the moaning posts about "rude" comments from others, you could have used that time to answer the questions of others in a constructive manner.
I have done inbetween in you check my previous posts.
This is what i mean, why are you so quick to go up against me?
Im trying to hold my hands up were due here so I can hopefully move forward contributing to the forum. Im explaining from my view how some comments people are making are rude so people can start to talk to me on my level instead of trying to talk down to me.
Will i ever be let in on such a level?
Hi Paul, any thoughts on post 22?
:smile:
My opinion has always been: that in order to conduct periodics, experience is required.
Problem with this, is how to obtain experience without first conducting periodics.
It used to be that you obtained experience while working with someone who had experience. Unfortunately, that no longer appears to be an option.
Now it appears the only option is to ask advice from colleagues (if you have any), or to ask on forums.
Experience and guidance under supervision is only no longer an option if you choose to qualify in a particular fashion and route.
Is it suitable and fair to gain experience by carrying out reports for paying customers whilst asking how to do your job on the internet ?
As Harry Callahan would say, a man's got to know his limitations.
Reply to RCD protection for circuits in a toilet (not shower/bathroom) in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Duh!!! Just re-read Op's original post, it was converted to a RFC!
The chances of any problem without the RCD are minimal, including it extremely negligible......with the supplementary, on a kin to Hannibal Lector...
