Discuss Rcd protection new regs in the Australia area at ElectriciansForums.net
so your sayin if you add a socket to an existing ring, buried in the floor/ceiling and in plaster you dont need rcd?
Some people are of this opinion.I understand it that if you are changing the circuit (adding a point)the whole circuit not just the new point needs to have RCD protection to comply unless the cables are maniacally protected or buried deeper than 50mm
What is the best way to provide RCD protection on a ring final circuit which you are modifying that is on a standard MCB but an old type board which no RCBO replacement exists? And customers does no want ugly RCD sockets?
Do you just add another RCD unit next to the board? or do you note on cert that circuit has no RCD protection?
Reply to Rcd protection new regs in the Australia area at ElectriciansForums.net
