telectrix
Mentor
basically, done a EICR for rental. 12 way wylex with 3871 MCBs, no RCD at all, so a few C2's and C3's. ideal world is a new CU with RCBOs, or even a dual RCD board. landlord won't pay more than necessary as it's a short term let and due to be demolished as soon as he gets planning for 2 houses on the land. upfront RCD would get rid of the "fails" on the installation, but 1 rogue circuit and the lot is dead. what would you do?
Obviously when you combine an MCB and an RCD , fault finding can become a little more complicated.
Thrown in an AFD on top of that that with occasional random trips
I may be overthinking it
The issue of false trips and diagnostics to prove if the AFDD is dodgy or there really is a sparking event on the circuit is a major point to me. Already we need to allow for the occasional RCD trip for no apparent reason (OK, usually something switching), but when a customer has spent £1-2k on a new AFDD board they really are going to be unhappy if that is more common.
Agreed, the more things we combine together the more difficult it is to diagnose, I used to be able to work on my car engine without a problem, but not anymore, unless it's mechanical.
I'm not familiar with AFDs yet in practice but that would be my thinking
If.u had one of those combi things trip once a month you could end up doing a lot of troubleshooting
Probably not too bad I suppose if it's only rcbo combi
I suppose realistically for a DB that's the way it has to be
All the protection combined on a single mod device
David Savery posted a number of videos about AFDDs, culminating with the video posted below. What stuck in my mind, relevant to the last couple of posts, is the fact that (at least some) AFDDs will indicate the type of fault detected when tripped.
Isn't the idea of a safe installation that arc faults don't pose a hazard without AFDs being installed
This has been discussed at length on the forum and David Savery has also investigated the matter in some depth.
I won't offer any personal opinion as I'm not knowledgable enough to confidently back it up, but I can recommend relaxing with a beer while watching Savery's commentary on the matter.
we didn't need transistors in 1940. we didn't need RCDs in 1960. the human race has survived. WTF do we need AFDDs now? just another money maker. same as ipaps.
Need smoke detectors and DC sensiive RCD = RCBO too,
due to all the Electronic carp we get cheap form china.
( If USB chargers of a reasonable quality are included in sockets - Maybe they will include an Isolate mode .. ( In my dreams ).
people wont risk nasty -Hold on tight shocks. from cheap n nasty stuff they plug in.
--Mains plugs moulded in soft plastic , on the end of washing machines-
..my WTF moment ! ..
telectrix
Mentor
cheshire/staffordshire
United Kingdom
Electrical Engineer (Qualified)
Business Name
Telectrix
RCD Quandary.
Thread Tags
telectrix,
static zap,
