T
Toneyz
Thanks guys for the posts I have no problem if someone disagrees and would do something a different way as I may say yes not thought of that for example. but I get annoyed when people puts dumb without a counter argument.
Discuss RCD Requirements minor works in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
...... chop the plug off and connect it into a FCU
Yes as your installing a socket outlet with rcd protection.just a 'technicality' query - the regs are not retrospective, so the existing circuit
(assuming it was installed pre RCD days) does not have to be RCD'd. Would fitting
an RCD socket therefore comply with current regs? ( Just curious! ).
but if you are feeding that new socket with cable buried in wall <2" deep, then 522.6 needs to be complied with.Yes as your installing a socket outlet with rcd protection.
the work you undertake must comply with the current edition of bs7671
Cables not directly in a wall according to the OP.but if you are feeding that new socket with cable buried in wall <2" deep, then 522.6 needs to be complied with.
Reply to RCD Requirements minor works in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
