rcd short circut | on ElectriciansForums
Discuss rcd short circut in the UK Electrical Forum area at ElectriciansForums.net
B
bmc48
my rcd 30ma trips everytime i put the iron on, it lasts a couple of minutes then trips , all sockets and lighting trip ,so its a big inconveinience,, any advice would be a great help. thanx,
Have you tried a new iron? I take it all your circuits are on one RCD? If you can use other items like the hoover or kettle on that circuit then it is fine. its the iron that is faulty and the RCD is doing its job by tripping.
[ElectriciansForums.net] rcd short circut
These never trip RCDs so get her one of them
If it's new, return it to the shop/site which supplied it for a replacement. It may be that the earth leakage from the iron is simply adding to the leakage already on the existing circuits. If the replacement iron has the same problem, have the rcd & circuits checked by a local electrician (post your general location on here - someone will be able to assist).
Regards
Reply to rcd short circut in the UK Electrical Forum area at ElectriciansForums.net
Thank you for taking the time to help explain this - much appreciated
Which rcd is it? Is it one for everything, one for a few circuits?
