rcd test tripping both sides | Page 2 | on ElectriciansForums
Discuss rcd test tripping both sides in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Had this on a rewire a year ago, later found one of the other sparks had wired the two way from the landing and hall wrong, 1mm's at bottom of the stairs with a feed and switch line, and a three core for the two way upstairs, the 1mm's for the hall light and the three core for landing light and switch fed it thinking it was a 1 gang switch not a 2 gang, could be a possibility
Yes really baffling me but fixed problem redid all tests and everything now spot on .but having said that builders are stil on site and loosening fittings to decorate and tile behind and such, so may have been something else as well .but i am paid now and everything was perfect when i left it
Reply to rcd test tripping both sides in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Yes I touched on diverted neutrals when I went over guidance note 3 the first time but I’m doing a second round and going between all books whilst...
Exactly. I was going to ask on the earthing once he clears this boiler fault (suspect on internal component). OP mentions oil boiler but makes no...
