RCD Test | on ElectriciansForums
Discuss RCD Test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
A
adam.h
Was doing an rcd test and when I did it on the upstairs sockets it tripped both rcds.
Doing it on the downstairs sockets it did trip them both, but I did the test a few times and was fine after the first. Every thing seems fine and did find a shared neutral on the lights but that is not used until its sorted.
Anyone know what mighty be the problem?
Hi Adam did you change the CU ? or are you just training ? if you did change CU whats the dead testing results ? if not start with split upstairs or downstairs ring and remove a leg (change into radial) then rcd test untill you get one rcd tripping if not try changing leg in CU untill you find the link.
Regards
Kung.
A straight CU swap. I'm new so very much still learning (mind, you never stop learning :p)
All other tests where fine and everything works normal, bar one light that trips it all out (having a shared neutral)
When I did the change there was a neutral on its own with an earth, no live. the earth was just a bare twisted wire so must be pretty old? But I left them unconnected.
Reply to RCD Test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Assumption is the mother of all major foul-ups! Start with the basics, like IR testing, RCD testing on its own, and checking the leakage as...
Thank you, what would be the advice for me to do in this scenario? I've also seen circuits tripped in past from other things such as 1500VA step...
