Ok so I have 2 chains of thought on RCD testing and I thought it would be interesting to see what you guys thought.
So when carrying out RCD testing I know you are supposed to test at the RCD, Now I was taught (and personally think is more beneficial) to test at the furthest point of the circuit the same as R1-R2 testing.
I believe this as at the end of the day the RCD is there to protect and if it tests ok at the RCD but due to some unknown reason does not test ok at the furthest point then I think this is unacceptable.
Again I dont work in domestic situations but whenever I test RCD's around site I always do them in the above way.
So what are your guys thoughts on it?
Do we have a split or does everyone test at the RCD? if so what is the benefit over testing at the end of the circuit?
Thanks all
Thanks all
