P
Paul Willoughby
Evening
I am about to install a Consumer Unit with all RCBO'S, I just checked my standard fluke test leads which aren't thin enough to test the RCBO at the Board.
Obviously this is not a problem for sockets or cooker as it has socket as well so can use plug test leads, but i will still need to test lights and water heater and would prefer to test at the board, as using this job to be checked for my part P assessment.
I assume Fluke do a thinner set of test leads for testing RCBO's anyone got any of these? and if so have a part number or know where I can get some from, assessment in 2 weeks.
cheers
Paul
the gs38 decision to shortern lead ends to 4mm is ridiculous. I've got some of the newer ones and can't say they've been used much, the connection is terrible.
If the fluke has standard 4mm shrouded probes then buy some shrouded needle probes that can plug into the test leads.
I think these are male fitting ones but you may find others out there if you need female fitting.
RCD Testing for RCBO with Fluke 1653
Thread Tags
Paul Willoughby,
Richard Burns,
TrueNAS JBOD Storage Server
