Rcd testing main board supply tripping befroe the sub board how do i get round it ? | on ElectriciansForums
Discuss Rcd testing main board supply tripping befroe the sub board how do i get round it ? in the UK Electrical Forum area at ElectriciansForums.net
M
Maestro
was testing portakabin DB today but when dong the RCD trip it keeps taking the RCD supplying the portakabin how do i get around thanks before hand
Re: Rcd testing main board supply tripping befroe the sub board how do i get round it
take the RCD out of the cabin if the supply cable needs RCD protection. if it doesn't need it, feed from main DB from a non-RCD way. 2 RCDs in series will give you this problem. bad design.
sorry i should have been clearer i am testing the portakabin in a workshop they are just plugged into a 32amp industrial socket which is being fed by a 32amp 30MA RCD
Posts #2 and #3 help you then?? Daz
Also,if TT to 32 A socket outside,RCD has to be two pole,but as told,fashion supply to test from non-RCD point.....and does it smell like a damp knicker drawer?...the three i was in today did...
Reply to Rcd testing main board supply tripping befroe the sub board how do i get round it ? in the UK Electrical Forum area at ElectriciansForums.net
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
