rcd testing | Page 2 | on ElectriciansForums
Discuss rcd testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Where were you testing the RCD/RCBO, at the device terminals or at the socket outlets downstream??
All RCD devices should be tested at the device terminals for your recorded values, and not at the extremities of the circuit. The circuit will/should have already been tested/proved via ELI, Continuity, Polarity and IR tests etc...
You are therefore only testing the RCD devices themselves for conformity, not the wiring...
that's not how we're taught at college........
Seems we have yet another collage lecturer teaching duff information to students!! This is getting to be a regular occurrence these day's!!!
Well i would suggest you get your lecturer to contact the manufacturers, who will all tell him to test RCD devices at the load terminals, and not at the circuit outlets!!
Nothing to stop you checking from circuit outlets, but not when your testing the device's trip/time parameters, when officially recording the results on report record sheets etc...
In his defence he is actually a good teacher and a lot better than most at the college. I think if you asked a lot of electricians they would test at the circuit outlets
No matter how good you are, you'll never know everything. Always learning.....
It's a good shout e54 I was also shown to test at socket outlets but was aware the gn3 says at device and I've had my 2391 since 1998 so I have tested both ways over the years so surely the trip times would be quicker at the device will retest at device
It would be even better, for both you and the rest of this lecturers students, if what he was teaching was correct and to BS7671 guidelines....
was back on site today e54 you couldnt possibly get your test probes on to these dorman smith rcbos so the test would have to be done at socket outlets but on your domestic dual rcd boards you could just test at the device thanks
If the test meters probes don't/can't reach the terminals, because of deep tunnels then connect a short length of cable (6'' or so) and test from these short tails. In fact some manufacturers actually recommend this approach to testing there RCD devices.... I personally don't like D. Smith MCB/RCBOs, and never have!!! lol!!
Reply to rcd testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It can also mean lasts or continues for two years.
Assumption is the mother of all major foul-ups! Start with the basics, like IR testing, RCD testing on its own, and checking the leakage as...
