Rcd Testing | on ElectriciansForums
Discuss Rcd Testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Djlelectrical
Been to a job today in sunny yorkshire, Using metrel 61557 tester and as soon as i hit start it strips the rcd on ramp test. Again on the rcd test on 1/2 rated current its trips the RCD as soon as i hit start.
Its on a TT System with 100ma Rcd and 30ma, Its the 30ma that trips as soon as I bang start. Testers fine as I have used it with susscess on the next job.
Anybody had same issue?
Reply to Rcd Testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
As per above from Dave. Swap to a 63A outlet and problem goes away. What gets plugged into it is not part of an inspection.
