RCD trip help | Page 4 | on ElectriciansForums
Discuss RCD trip help in the UK Electrical Forum area at ElectriciansForums.net
sirocco
Just been called out investigate RCD tripping on downstairs ring at my parents it just went in the early hours with no history. Have unplugged all appliances from the 10 sockets on this ring and switched all sockets off. There are no other appliances fed from this ring other than those plugged in via sockets. There are 3 other circuits protected by the same RCD in the CU ie Shower, Cooker and upstairs ring, these are all functioning normally and don't trip the RCD. I have substituted the downstairs ring MCB but the circuit still trips the RCD immediately when the MCB is switched on with nothing plugged into the sockets. My next step is to disconnect the ring, split the dead ring at the midpoint and test each half, but before doing this I removed the 2 CPCs for the ring at the CU from the earth bar and the circuit now stays on and doesn't trip. Before I plough on , disconnect the phase and neutrals and do dead circuit testing is there anyway that I can identify why the disconnection of the CPCs allows the ring to operate? Graham
Power Ranger, it has already been confirmed that there are no parallel paths at the start of this saga as the rcd tripped no more when the naughty boy took the cpcs out of the met.
The lesson in this thread is that you can take a horse (aka Electrical Trainee) to water but you cannot make it drink.
Oops, no, I dont have a horse parked outside customers houses, said it before Biff.
Boydy
Ah lesson learned today: read all posts in a thread before posting myself.
Just an IR test between line and earth was the most logical thing to do. .. I dont understand why this was not carried out.
First thing to do should have been an IR test...
Boydy
Boydy, Yes of course, your right on that count in that its obviuosly a L-CPC fault on this circuit. So apologies if I caused a bit of confusion on the thread as Sirocco would still have found the fault doing IR tests with the CPCs disconnected at the MET.
However, if he had removed a few sockets including the one with the fault on it before doing any IR tests then he would have probably cleared the fault on this occassion and so would have not found anything wrong. Therefore, I probably now guess that as the RCD is holding on that the fault would now be only found on close visible inspection of the Line conductor insulation at each outlet.
But what I was originally getting at, is that quite a few electricians do their IR tests with the CPC's isolated from the MET and I just got the impression that Sirocco always did this as part of his normal testing procedure.
Re: rcd help!
When i rcd test with my fluke meter it works on some circuits and on the rest it reads 310.0 Ms an wont trip!! Wots up?? Please help!
How are you testing? more info needed.
Not familiar with the fluke but it's probably going over-range at 310ms. Make sure all loads are disconnected before testing,as these can cause longer trip times,particularly loads with a capacitor.
Reply to RCD trip help in the UK Electrical Forum area at ElectriciansForums.net
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
Ok I’ll try this when I’m down
