RCD trip time tests | on ElectriciansForums
Discuss RCD trip time tests in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
biggrilla
Hi folks,
Hoping somebody on here can give me a little bit of advice. Just tested trip times on a 30mA 61009 RCD, greatest time at x1 was 24ms and at x5 was 28ms.
I know the regs state that at x1 under 300ms is needed and at x50 a reading under 40ms is required - but should the x1 reading be greater than the x5 - or is it "just one of those things!"
Thank you in anticipation of help!
BigGrilla
I realy woulnd worry about it yes they should be the other way round, but they both pass it could just be down to the slightest difference in connection.
I would even say if you were to test agin it would be different.
I wouldnt worry about it mate.
Jim
bleedin rcds,fitted a dual board recently,one rcd kept tripping on half cycle,done ramp test at 30ma,showing 14ms,fitted replacement same sort of thing,ok i was getting annoyed by this time,must have reset that thing 20-30 times and then it started to play ball,this was a brand new hager unit,so i take it citys dont sell many as they sit in the stores for some time,wonder how many rcds out there never get tested with button,easy for them to seize up a bit.
Reply to RCD trip time tests in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
As per above from Dave. Swap to a 63A outlet and problem goes away. What gets plugged into it is not part of an inspection.
Assumption is the mother of all major foul-ups! Start with the basics, like IR testing, RCD testing on its own, and checking the leakage as...
