RCD Trip | Page 2 | on ElectriciansForums
Discuss RCD Trip in the Talk Electrician area at ElectriciansForums.net
your old board saw all neutrals as common neutrals & your new consumer unit has 2 RCD's one neutral for each output of the RCD's installed although at the beginning they are common not on the outputs of each RCD, all as above really.
I had initially discounted Neutral Earth as had not tripped on old RCD or the way I have Left it.
Had passed my brain as Neutral in wrong place. Which probably meant the initial installation ( some one else, before I bought the house) was wrongly labelled ( luxury) or they had crossed up a ring main. Neutral wrong place was my first thing to-
morrow. Thanks
Reply to RCD Trip in the Talk Electrician area at ElectriciansForums.net
Which rcd is it? Is it one for everything, one for a few circuits?
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
